mongoosetoo
- Oct 19, 2005
When I start the GNutlass (85 GN) it fires right up. If I shut it off and try to restart, I have to wait at least 20 minutes. Sounds like a coil or ignition module???
This problem just a started after I put a cold air intake on the car and rewired the electric fan. The only rewiring I did to it was use the coil braket as a ground for the temp switch.
Since the engine does not have a provision for a temp switch to control an electric fan or a port for an aftermarket water temp sensor, I made one. I used a pipe the same diameter as the upper radiator hose and welded two bungs on it for the switches/sensors. I also welded a bolt for the ground/mounting bracket. This is how I grounded it, through the framework of the coil bracket. I did not remove the coil or disturb it in any way, I just drilled two holes in the hose support and mounted my bracket to it.
The cold air intake was pretty straight forward. I just removed the old air claener and plumbing up to the MAF then plumbed in my own stuff. I wanted to use aluminum pipe, but only need about 6 inches, so instead I used PVC and painted it flat black and then mounted the new conical K&N style filter to the other end of the pipe. I intend to put up an aluminum barrier wall between the air cleaner and the radiator to draw air exclusively from behind the left headlight. It looks good for cheap. I've got $46 in the filter and plumbing.
Anyway, the car is having problems. One thing I did that was out there a little, is I needed a power source to energize the aftermarket fuel pump relay, so I am using the brake powermaster ( I have vacuum brakes now) to supply ignition power to my fuel pump relay.
One last thing, my ECM will not enter diagnostic mode when I short the pins under the dash.
Thanks, Brew
Thanks, Brew
