Eric,
TT Forum was timing out for me so I thought I'd ask for your input here. I've attached a log I made today with my manual boost controller set for about 30PSI. As you'll see from the log, right after WOT I get a little bit of knock and then as the A/F goes down and the turbo spools the knock is gone all is well.
Is there a way to increase WOT throttle with your chip, like a "power shot" type setting? Or decrease any delay that is there before PE fueling takes place?
Have you seen this before, could it be something else? Car is running awesome.
