esc module replacment
chops
I had a code for that last month and today the car started popin like crazy and check engine light flashing car does. Not start now check inj pulse ok.fuel press ok.spark ok.tomorrow am going to check with my scanner if I have rpm while crankin that will tell me if the crank sensor is ok but am leaning tords that esc module that could also be the reason am get det at high boost maybe ? If it is the esc is it still available and or can I replace with a different set up?
