Et gain with 350 trans?
esm
what is the et gain from going from a 200r4 to a turbo 350?
FWIW, I've seen a gain going from a 400 to a 350, and again going from a 350 to a 200-4R. Not the other way around.
On a high powered application that has 9 sec or faster power there is e.t. to be gained with the taller first gear in the 350. If you dont have 9 sec power the gain would be small or it coul dbe a loss if you dont have the car dialed in for harder launches
thanks
thanks for the info -- i thought it had less rotating weight and would gain
from the 350 trans ---- thanks again for the info
Gain
We switched in the mid 90's 94 0R 95? to a turbo 350 and did not notice a gain in ET? WE also DID NOT break trannies like everyone else since no one could build them RIGHT back then. This was on a 10.50 car at 126 mph. We probably would have been the first stock block in the 9's but life and family's got in the way:biggrin:
