After driving the GN around the block a few times I noticed a whining noise coming from the rear end.  My pinion seal is also leaking.  I initially though the noise was from the backlash being too much, but I was pretty confident that I set that correctly when I put in all new bearings and seals awhile back.  I will be pulling the rear end apart tonight, but I'm assuming the noise is from the pinion bearing now.
I did my best to use a in-lb torque wrench to tighten the pinion nut until I would get it to click at 25 in-lbs when I turned the pinion nut while the ring gear was out. I was trying to measure resistance of course. I thought that was what I was supposed to do, but at this point I'm guessing that the pinion nut is too loose and the pinion is walking around.
Also, the replacesment crush sleeve was a larger diameter than the original. Is that correct, or do I have the wrong one in there?
HELP!!!
HELP!!!
