I have tried to get the thing to seal a couple of different times. Then I figured screw it, the puck is sealing perfect. But, does the seal of the exhaust elbow cause problems once the puck opens??
Just got my RJC boost controller hooked up. The car feels ten times better getting into boost. It hits 15lbs. of boost then settles right away at 13lbs. for the rest of the test run. So, could that be the exhaust elbow not sealed properly? Its the only exhaust leak I can hear. I did put JB weld on it a month ago to make sure the leaking wasn't causing my boost issue at the time. The JB weld sealed it up nice and quiet, but that wasn't the issue.(stock adj. wastegate was bad) So, the JB weld flaked right off after a week or so of driving
I was thinking of JB welding it and seeing if that is the culprit for the drop in boost. I know JB welding it sounds stupid but it was a good trial and error. :redface:
How is everyone sealing theirs up......just metal on metal? May I have to get the elbow or turbo resurfaced??
I could just turn the boost up to 17lbs. and then let it settle in a 15lbs., but I just want to be able to run at a constant level. Especially on 93 octane.
TIA, Nick.
TIA, Nick.
