TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Can i get just those thin mufflers ?
Working on it. Not sure why you would call them thin though???
SignUp Now!Can i get just those thin mufflers ?
You have to come to a common ground between noise levels and performance gains. Bottom line on these cars is backpressure=performance lost. The best performance exhaust would theoretically to cut your DP off right after the turbo. You want the best free flowing system you can stand to listen to.
unless i'm missing something, you already have all the parts to easily go 12's. your street tire 60' is decent, but slicks would net you another .4-.5 off your et. if it were me, i'd just up my boost to 22ish, add timing til she knocks, then back off a bit, and you'll be runnin mid-hi 12's all day long.
If your all about performance gains I doubt the butt dyno is going to show much with exhaust.:biggrin: If your exhaust is in good shape I would look elsewhere. I noticed way less back pressure with the single exhaust. My boost numbers went up with only an exhaust change.
had super comp turbo's and i switched them out for max flows. both systems are quiet, no complaints when cruising either.Hooker cat-back (or similar) system with a straight-through type muffler (MaxFlow, UltraFlow or similar) will have much less drone than any chambered or baffled-type muffler in these systems.
maybe I'm an extremist, but I don't think the 3" single shot is really that loud, nor is there too much drone with it. My LS1 with headers and the Corsa catback even with extra Dynomax bullet mufflers in place of the cats is louder than my Buick.
Plus, its always nice to bounce that noise off of curbs, under passes, retaining walls, slower traffic, etc....especially when it all comes out one side!
