Extender chip revision E, need an upgrade?
22lbChevelle
So im running a maf translator with a extender chip E. Should i upgrade to a new revision or switch to a turbotweak? Please explain why or why not! Thanks, Dan
Are you plannning to run a wideband setup?
The current rev. is "F", and' I don't remember what changes were made.
I would say, if you're happy with your Extender, then my recommendation would be to stick with the Extender line and upgrade to F.
There are plenty of Extenders available, to fit any need.
Extender (for use with Translator
Extender Extreme (for use with Translator Gen II)
Extender Pro (for use with Translator Pro)
Rev E has 4 adjustable parameters
Rev F has 8 adjustable parameters.
If you don't need the additional adjustments and the car runs the way you want it, then there is no real need to change. Otherwise, The chioce would depend on your goals and intended usage of the car.
Bob
Thanks for the replys guys. Yes I do plan on running a WB at some time but not in the near future. What does this change for my decision?
It doesn't change anything. A wideband is a wideband.
