turbojimmy
Supporting Member
- May 26, 2001
Hi all,
I'm heading back to the track Sunday to see if I can best last week's times. I ran 12.2 @ 111.6, but given my mods I think it has a lot more in it. I think my biggest problem is that I had the alky coming on WAY too soon. There were some other minor problems, too, that I hope to resolve.
My question is about adjusting the timing via the T+. I'm running an Extender chip burned for "alky" (98 octane) with 23/21 timing. Last time out, I turned it up to 23/25 and 24 PSI and had no knock (again, drowning in alky). I'm only adjusting the WOT timing. Questions are:
- when does WOT timing "kick in". My TPS was messed up, so I I don't think I was ever really getting to WOT or PE (4.3x max voltage)
- would it do me any good to adjust the base instead or in addition to WOT (I know if I adjust the base, the WOT goes up with it).
- Should I concern myself with MAF adjustments at this point?
TIA,
Jim
TIA,
Jim
