Exterior Trim Paint Recommendation?
jpwahler
Guys,
Any recommendations on a quality spray paint for exterior trim for a GN?
Thanks!
SEM makes two different gloss levels for trim paint.
part #39143 original trim black = flat black
part #39063 gloss trim black = is more of a semi gloss black
They also have a honda black part #39293 that is between the 39143 and 39063.
If you go this route, you have to be patient and apply multiple thin coats to get a smooth finish. The finish will not be as smooth as would be if it was sprayed with a spray gun.
trim paint
duplicolor trim paint in a green can sold at AUTO ZONE used it on mine ,holds up well in the desert heat here in vegas ,goes on kinda wrinkle looking but dries great
