Cool these are awesome pumps they will increase pressure and personally I wouldn't think it's overkill to have a bitchin oil setup that can supply the life blood of your motor . Thanks anyway
I totally agree. You have a set up kinda like this on another motor right?
So what do you all have with this? All hoses? Remote filter set up? Is the frame notch needed on this one or was that a similar but different set up that required that?
I have a TA external pump on mine which is very similar . Basiclly you need to run a line to the oil pan for a pick up usually a -12 then a line from the pump to a filter then filter to the block . I have some -12 line . I might have a extra oil pan that's setup with a external pick up .
