F.A.S.T, Fuel M
njrob6
Mustangs For Breakfast
For Sale:
F.A.S.T. Sequential Fuel Mnanagement ECU w/ ind. cyl. control, 1 Wide band O2 Sensor, MAP Sensor, laptop cable, software.
no its not xfi
For those that may not know, this is the top of the line box when it comes to a Classic FAST
I have a complete new TCI engine harness for $250 if you want to change out your stock harness or you can get an adapter harness to make it work with your stock harness, check with Cottons Performance maybe for a price.
Rob
Info
Do you have to run mass air flow with this unit / I'm interested
A stock harness will not work with this, it needs the adapter harness which I dont have to make it work. Cottons Performance may help you out with that, im sure its not that much.
