F.A.S.T has released another public update
Otto J
C-ComWP™ Software
One thing this update lets you do is change from a map reading KPA
to % of engine load
It also comes with a new flash revision 4B
This update also supports the internal logger that can be purchased from your XFI dealer
Please, also remember, as I have found out, to check your current firmware version on your XFI first. If you have any other version, basically older, than version XFI2_45, then the update will change your tunning files, and you will have to go through the instructions that are listed on the FAST site, to change them back. If you are unsure which instructions I am talking about, you will see them in PDF form before you actually download the program.
If you currently have XFI2_45, then it will be a painless update.
For those that are interested in the internal data logger feature, you MUST have C-ComWP XFI version 1.332, and firmware XFI2_4B loaded, before the option file can be enabled.
This is information that I have received.
Don't download, yet!!!!
I would hold off downloading right now. It will be updated tomorrow with a slight improvement.
I see trans brake control with creep feature. Sounds interesting.
Greg Kring
I just down loaded this morning, is this the newest yet???
Just wired up the internal logger and checked it out,Works great!
No more clumsey laptop at the track
