SignUp Now!87boostedbuick said:F body rad has a spot for tranny cooler I never used mine I ran external coolers for engine oil and tranny fluid
No, the f-body radiator does not have the oil cooler.Does it have one for engine oil? I already have an external trans cooler
sure it does...i just did this swap. i'll post pics later.No, the f-body radiator does not have the oil cooler.
Found the answer. I re read the install on gnttype and they recommended not using the trans cooler for oil cooling
That was my question. The radiator I bought just has A trans cooler in it. I already have an external trans cooler and was thinking of using the trans cooler in the f body radiator for the engine oil cooler. I re read gnttype's swap write up and they recommended not using it that way and just use an external oil cooleris it a bad idea to use the cooler as an oil cooler? ....this is what i did...i've got external cooler for the trans.
Awesome. I feel better about using mine now
