Running power steering fluid in system.Fluid level is correct.
1st issue
Steering wheel gets very hard to turn while applying brakes,at slow speeds.Return line has no kinks.If I hold the pedal at idle it virtually impossible to turn the wheel.(possible PS pump going out?)
2nd issue
You can still feel brake pedal "stick" at one spot while applying brakes.Not related with the brake,cruise sensors.Only"sticks while engine is running and at low speeds while braking.Once I hit the "stick" the car nose dives like I mentioned in a previous post.Pedal will not "stick" with car off,the pedal is smooth all the way to the floor.(Possible bad power booster?)
1st issue
2nd issue
