fan connector wires
volvoman
The Green BEAST
Is there any other GM connector that will work with the gn harnness for the fan?
I want to splice my ford 2 speed fan, so I can plug it into the gn harnness..
If there are any other places I can find one that would be great.
Chris
I'd call John Spina at Casper's Electronics. I used the dual fans GN wiring adapter he sells and cut off his connectors (to the fans). I then saudered his adapter to my LT1 fans' connectors. It's now plug and play. Worked great for me, maybe you could do something similar.
I just might end up going to the yard and pulling some 3 wire gm conector and splicing it in. I will check out the page though..
thanks
Chris
