yes, I can...thx for answering...It can't be the chip, I sent it back already and it was checked. It works perfectly on the scanmaster, Numbers are where it should be. Accept the fans turning on. I even made sure the chip was install property. The ECM(Computer box unpluged), I had it sent out and checked out a couple of years ago with the stock chip installed, checked out OK. everything's good. The ecm reads the temp raising with scanmaster and gauge(gauge reads higher).
The Fan Resistor, There's 2 terimals for wires. One side rusted out and broke off. Connected all the wires on the resistor to the otherside on the Resistor.. I did a test with the fan alone with the fan plug straight to battery, The fan works. Just not when its connected to the engine harness. I'm thinking maybe the temp sensor or connectors to relays(The relays are new). I pulled all the fuses inside the the car and checked if anything is brown, it's all good.
The AC compressor switch plug when it's disconnected & ignition on and test with one wire on pin's on the connector plug with the other end of wire to ground like sheet metal, Relays click but Fan don't turn on. Checked volts with multimeter on plug, there's 12Volts?
