I Fixed my Fan problem, I think it was the FAN CONNECTORS after a very long thread....Reading Vortexbuick troubleshooting, The info testing does help and narrow it down.
-Checked all fuses under the steering wheel/with a test light for power.
-Checked all relay connectors for power/ with a test light or 12 volts with ignition on.
-Fan runs when connected straight to the battery or power directly.
-Disconnected the fan delay relay plugs from the relay and leave it there.
-Replaced old Fan plug & wires with Caspers harness(CONNECTED ALL WIRES TOGETHER, DELETED THE RESISTOR COMPLETELY FROM THE FAN).
-Replaced old Engine Fan harness plug with Caspers
-Reset the chip or disconnect the battery.
After sitting in the driveway at idle when temp rises, fans turned on at high speed at 167*, like its suppose to by the TT chip or (ECM). I'm very glad I figured out this fan issue, after awhile.
