GotGas8668
- Apr 9, 2003
I'm having a problem where the fan will not come on unless I put the ignition to run and then back off and then to run again. I've checked all the relays, doesn't seem to be the problem. I do have the high relay ran to a ground wire so that the fans run for about 10 minutes after turning the car off. This has been done for a long time, though. I did find on the main fan relay, that if I gorund out the red wire on the back harness of the two, that it turns on correctly. I'm thinking of grounding this wire permanently. Any other thoughts?
