Fans kick on at 208 degrees and off at 199. They kick on immediately with the air conditioning like they should. Last time this happened it was the radiator fan switch (mounted vertically on driver side of intake) so I replaced that first. No change. So then I put in an old coolant temp sensor that was working when I removed it 3 years ago (mounted horizontal on driver side of intake). Still no change. Fan motors and relays must be working if fans are coming on, correct? Connector to coolant temp sensor has 5 volts. I think the radiator fan switch connector had 12 volts if I remember correctly. Any suggestions? The thermostat is 185 degrees.
