There is a parameter that you can log. On the older Calcom this was called TPS AE.
There is also a parameter called Delta MAP which should apply some AE depending on your settings, but I don't know how to log the MAP AE by itself. Maybe this can be done in the newer versions?
I mostly just tune this by feel, but it does get complicated when you have a turbocharger that gives you boost lag.
-Bob C.
