Just as the title implies, I recently had my FAST ECU switched to SEFI and just plugged it in and now it just cranks and won't fire. I loaded on the last .gct file I had when it was B2B and the ECU params have been set to enable ICC and SEFI. (Nothing on the car was changed while I waited for the return of the ECU.)
I now have the OEM 4.6 Cobra cam sensor wired up and it's set up to run with the OEM EDIS Ford module. Both the wires to the cam and crank are the correct polarity (+ -), but I could switch the polarity to see if that makes it fire? I did re-wire the crank sensor polarity because it looked as though I had the FAST positive to the OEM neg and vice versa.
When I got the ECU back from FAST I just loaded up my last .gct file from when it was B2B and erased whatever was on there from FAST as far as a .gct file goes, but that shouldn't keep it from firing... I should have just saved what was on there, but it looked wayyy different as far as the VE table etc., and so I figured it was something completely different they had for bench testing it. The way I understand it, the SEFI and the B2B .gct files should be compatible...
Any suggestions?
Any suggestions?
