FAST boost solenoid??
ghall
I am getting ready to fire my new combo up and one of the last things i need to do is to get the FAST boost solenoid installed.
I will have some pics below--i just want to make sure i have this correct.
The brass fitting goes to the top of the wastegate, and the AN fitting is coming from the turbo?? The open port is the exhaust??
Does this sound correct?
On the wiring---one goes to ground and the other goes to c8 of the FAST????:confused:
Any advice from someone that has installed it would be great.
The solenoid "in" comes from the turbo and the solenoid "out" goes to the top of the wastegate. The wiring should be to C8 and the other wire should go to switched 12 volts
