I need help adjusting my FAST cold start idle. Ive got the hot idle working OK, but the motor seems very fat and surges and dies when first starting the motor unless baby sitting the throttle. I am not running an IAC. The motor is a 397 inch twin T-76's Olds SB. It is sequential the cam is synced in at 80 BTDC compression stroke. I got a tune from Harry Hruska it was close but needs something so the thing will start and run when cold without holding the throttle. Injectors are 160's TB is Holley 95 mm. Its sorta odd set up the plenum volume is rather large due to the IC sitting directly on top the sheet metal manifold due to space constaints. I dont know if the excessive plenum will cause it to be more difficult or not. The fuel pump is the Aeromotive belt driven unit, primes super easy and hold rock steady PSI with the weldon regulator. Any tuning ( even hot idle or wot ) help is greatly apreciated . Thanks Russell
