Roland Black
- Dec 20, 2001
My ESC system on my modded Syclone does not work. I have beat the living hell outa the upper intake with a rubber mallet, and then the alternator housing with a steel hammer. I CANNOT get the damn thing to show any ESC retard. I have a large sledge hammer, but really hate to further "dent" the powdercoating.
I spoke with Jim @ PTE today and got info regarding all leads and voltage requirements. I found a ground lead that was open to the ESC module and repaired that. NO difference. I tested the stock SyTy knock sensor as per the Sy supplement, and it tests ok (shows voltage if ya beat on the motor while in the 2v ac mode, with the connector undone). All leads to the knock sensor, ESC module and to the ECM are now good. I also borrowed another known good ESC module from a local TB friend, and still no difference while whipping the **** outa it.
Harry (PTE) wasn't in, but Jim mentioned that Joe thought that there is a place in FAST where you tell it you have a knock sensor. The only thing I have found is the ESC parameters which are filled in. Is there some secret hiding place that I haven't found?
Short of ramming this MF'r into a telephone pole while recording a run, anyone have any other ideas? Thanks in advance,
