Had a AIS equipped car today on the dyno with which I had more trouble getting to run then the other non AIS ones I have done.
YOu crank the key, it would start for a second, then die. If you tapped the gas pedal twice though just a millisecond after the start, it would stay running, and idled very smooth.
I tried everything I could think of, every table, increasing startup AIS, cranking fuel etc.... could not get it to stay running without tapping the gas pedal. Had P &D calues icnreased to 60 and 12...nothin.
I went into global parameters, and increase the "time to run" (or whatever it is called) rpm to 500 (was at 300), and it seemed to do the trick once or twice, then same deal as before. Customer was in a hurry, so we dialed in everything else.....
Any suggestions?
86 vette. Wide band option, mild 355 motor.
Thanks,
Toma
Any suggestions?
Thanks,
Toma
