What processor on the laptop is required to run the new F.A.S.T system? PII, PIII, memory, etc. Would the same laptop run Direct Scan for another car? (not at the same time, obviously)
You might do a search on this BB on the direct Scan to see what is required.
The FAST system that is current is C-Com WP this is a Windows base program. The Direct Scan is a Dos base program. So I guess if you want to use Windows XP you will have to split your hard drive to use Direct Scan or use an older operatiing system. There may be other ways to make Direct Scan work on the XP system but I don't know them.
Thanks Bob. Trying to decide whether to upgrade now to FAST or wait until Stage II is finished (could be two years) I would have to purchase ME-R or similar for now. Currently running a 109 motor in the mid to high 10's. Thanks again.
