FAST/Speedpro sensors ???
draggin3
i need an air temp and coolant temp sensor for my fast/speedpro box. will the sensors from a camaro or firebird work and if so what year? thanks
actually with the IAT sensor you need to make sure you get the one with the holes in the thermistor.....i dont believe the f-bodies that early had them
Actually, a late model style isn't needed, as the early air temp sensors were more like coolant temp sensors and in the case of early app's they could be inter-changed. The newer sensers are better though for air temps and can be found in '91 LT1 's F, B and C bodies.
thanks for the replies. autozone had a catalog w/ pictures (i knew what they looked like just didn't know the p/n) and i was able to get the right ones. thanks again.
