I'm working on the getting the baseline VE table down and experience some oddities. Anyone have the ABCs of establishing the VE table?
Respective to AE 'Rate of' tables I take form that its only when TPS and MAP are designated to be moving. Today I was in the empty warehouse parking lot holding 1st gear though 900, 1400, and 1800 rpm to see where VE wanted to be at. Generally I was looking for a strech of about 5 seconds where the MAP sensor was fairly constant (+- 1 or 2).
The motor will idle decent in the 14.4 range and accelerate ok. However, I'm curious as to why VE cells near the idle area are in the 69 to 70 range. This seems a bit high?
Any ABCs of getting VE base established?
For the most part, I can get the motor to slowly rev smooth when in neutral. I'd gather the AE vs. TPS rate of change is close. However, under light load I get a tip in condition. I'm looking to adjust AE vs. MAP rate of change.
Edit: My TPS at idle hangs around 14% and 96% WOT
Where does AE ve. TPS position and AE vs. Coolant come into play?
