8
89 coupe
Guest
I am currently helping tune a 347 Ford with FAST. This car had a XX Mondo Vortech blower and most of the VE numbers under boost were in the 100 range with good control of the mixture
We just installed a Procharger race blower. This blower puts out roughly twice the airflow of the XX trim.
This blower is rated at 3600 CFM max and the Vortech was rated at 1850 CFM max to give you an idea of the differences.![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
I know we will climb the VE chart much faster now than we were and we had a good tune with the previous blower. Do we just need to use approx the same numbers (around 100) to start with moved over in the chart or will the actual volumetric efficiency be way higher with the new blower and need numbers (around 150).
1. We are just looking for a good starting point with the new amount of airflow we will have and wonder if there is a formula available to help us achieve the results we are looking for in an efficient manner.
2. We want to be close enough on the first run not to hurt the motor by going real lean. (Most important)
Martin
Martin
