My car is somewhat bogging in the 60'. I went a 1.55 last time out but it seem to bog after I let off the t-brake. The only reason it went a 1.55 is because the track hooked real good. It looked like the car wanted to carry the wheels but it only jerked them off the ground.
Now the question I have is my acual A/F ratio is in the high 9's when the car did this. I noticed on a couple of data logs before I was using the two step that this didn't happen. It would launch and run close to the 'target' a/f ratio throughout the 60' and beyond. So what do you have to do to the VE table to get it to work with the two step? I already have the 02 sensor turned off until after I let off the t-brake. Target A/F ratio is in the 11.5 range which I know it can go leaner. Thanks for any suggestions.
