434nova
- Sep 30, 2013
I have a couple questions for those with the xfi. Do you need to hook up the air temp sensor ? I have read that people have relocated there sensor into the dog house of the intake manifold does it have to go the or could it be installed into the air intake pipe on the throttle body? Also when installing the 3 bar map can i just replace my 2 bar with the 3 bar in the same location and use the same map sensor plug or do i need to use the map sensor plug on the xfi harness? Thanks
