I just finished installing the FAST XFI on my 87 t-type. Got the car to crank up but noticed no KPA reading. My original thoughts were that the computer saw boost readings from the 3-bar map sensor on the firewall? Now I have concluded this is for the hokey guage in the instrument cluster.
On my Eclipse the AEM read MAP through the old MAF wiring system. Is it done the same way on the XFI? If so is there a jumper cable or can someone direct me to the wires on the MAF I need to run the MAP sensor to?
As I said the car starts and idles perfect, but as soon as you get in the throttle to much it cuts out from what appears to be a lean condition. Put the car in D it cuts out from what I am sure is the car being put under load and the XFI not reading a MAP reading to tell it to adjust fuel.
Let me know if this makes sense .
