FAST XFI - "Shaft Connection"
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
Ready to connect my GM Flex Fuel sensor to FAST and haven't a clue where I might find this connection! HELP!!!
Conrad
That is what I had assumed but, after looking at the pinout for the box (see link below), I don't see the shaft connector listed. HELP!! Appears to me it is part of the FAST VSS & Aux Shaft Harness kit (part # 30-1403) but connot find a photo of this or any indication of where it is located.....under the dash??
Conrad
http://www.fuelairspark.com/products/documentation/xfi/help/Chapter3.htm
It seems as tho they use the shaft inputs to run the xfi, if that's the case pins A2 A6 A13 A17 will have to be used. Obviously Cal would be the guy to consult about this.
According to an old communication with Kevin Winstead with FAST, GM sensor is connected as follows:
"Flex Fuel sensor Pin A signal foes to Pin B of XFI shaft connector
Flex Fuel sensor Pin B signal goes to 12v switched power supply
Flex Fuel sensor Pin C sensor ground goes to Pin C of the SFI shaft"!
That is 3 wires...not 4????
Conrad
Conrad
Makes sense.
If your XFI utilizes the Casper box and wiring, your wiring harness does NOT have a Shaft connection! I talked with Kevin Win stead with FAST...he has several TR's....one has Casper XFI setup and one has FAST harness that DOES NOT use Casper box! Hell, I didn't such a thing existed.
Conrad
Conrad
Conrad, I ran my flex sensor (2012 GM Flex sensor) signal wire to A6, 12v to ignition on power, and ground to ground.....
Seems to work. My fuel constant went from .680 to .698 on XFI
