SignUp Now!Less expensive than a dizzy???Somone need a calculator?
6 coils+XIM module=$$$$
We are in the process of converting a GN to coil-on-plug as it has a FAST XFI already installed. This will perform as good, or better, than the distributor set up, be much less expensive and work on street cars with A/C.![]()
We have the experience of doing this on other cars, so it is a matter of adapting it to the GN. Dyno testing has confirmed our better performance results.
When the street version is done, we will do a race version as well.![]()
Nick,
Are you using the XIM Module for this? If not have any of the FAST dealers used it yet with the XFI box?
Nick when will this be ready? Whats the difference between the street and the race version?
Yes, we are using the XIM box.
Doubt that other dealers have done anything for the turbo Buick application, but it has been done on other makes
Right now we are very busy as our race season is in full swing. It will probably be 2 months before we finish testing.
The major difference between street and race will be in the wiring harness and location of the coils. The race version will be a stand-alone harness w/o provision for AC.
I spent $250 for a 7al2 box, $150.00 for a distributor, and a MSD crank trigger cost me $225.00, but you can get it done with the stock crank sensor. I'm curious with the cost of LS1 coils, XIM, harness, cost for mounting the coils how it will be MUCH less expensive than the distributor setup? Tony Gomes has a distributor on his TSO car with A/C also. The Crane ignition box is less than the 7al2 MSD box and has proven to perform well also.
What trigger wheel does the XFI/XIM use for crank reference?
From Summit:
So who the hell cares that you got a deal on some used parts?
Also, I know Tony has a dist. on his car, but again, who cares?
My car has a dist. and it was a PIA to make it fit and work, and I do not have AC.
I have been working with a local tuner and dyno operator, and Ken Dutweiller who was kind enough to spend time with me to discuss this project.
As far as tech details, this will be provided to those that purchase kits. For someone that want to copy it in China or wherever, they will have to buy a kit too.
Why do I have to justify to you, or any other self-proclaimed critics, of what I am doing or how I am doing it? Answer is I don't.![]()
Seems lately there is a rash of personal attacks, unwanted and unwarranted criticism especially toward vendors. If this sounds "abrasive", it is because I am personally tired of constant trashing on this board by a few. There are many other that share this sentiment also.
It is a place to share and exchange information, helpful comments are appreciated, hateful and negative stuff has no place here.
It seems that you have limited knowledge about the XIM and how it operates, Have you seen the trend in the automotive industry, going to cop ignition, not putting in distributors. The advantages over the conventional electronic ignition are the elimination of a mechanical distributor, increased voltage at the spark plug, better timed spark, and a more efficient running engine. I for one would like to know that my spark is accurately firing at the correct time. With a distributor you will always have the timing chain and camshaft whip to contend with, and the associated noise induced from a conventional ignition. With the XIM you are not limited to LS style coils, you can run any style or output of coil. Hell we are running 8 HVCC msd coils with one. Smart or Dumb coils are able to be controlled by the XIM.
But Ted you should know about this advantage as you have a Big Stuff 3 that should have the capability for cop, or doesn't that feature work properly yet??
I think that this should be an excellent option for those running a XFI and wanting a more reliable ignition, with two step capability. For those that don't want to loose too much of the stock appearance or A/C functionality. And it will work with all the factory cam and crank sensors.
