I just got my FAST. It is used and there are no instructions. I need to know how to hook up the MAP wire and the fuel inj. wire. Also will the car start without the o2 hooked up/ I don't have it yet. Thanks
If you don't have the O2 yet, BE SURE you check the S/N on the box w/ the S/N on the sensor plug. IF they don't match, the system will not work. You then will have to buy a new sensor from FAST that matches the box...
Did you get a disc w/ the box? Is it Windows version?? If not, I'd recommend you buy that upgrade.. It's cheap.. Like $35.00
Further, if the box is several yrs old, I'd call Craig at FAST, [810-225-2700] and ask if there are firmware upgrades that need to be added. [Have the info off the box when you call] That's cheap too.. Bout $40 plus postage.
Back under my rock, and tunin' on the FAST!!.
