Fastening SE headers to GN1s
vacuum 6
Going to use set screws with serrated flanged nuts. What lengths set screws?
What are SE headers?
I have TA headers and TA heads. Most of the studs I used were 3/8-16 X 2". I ordered the studs through a local Fastenal. I had to go to a local Ace hardware to find smaller stainless washers that fit better around the header tubes.
The longer studs on the driver's side I'm not sure on the length but got them through Earl here on the board. They do not have the allen head though.
If you could find a ARP 12pt style nut I think it would work better than the standard 6pt nut. The way it's tapered gives you a little more wrench room.
Hope this helps!
