Fastest Passes with the Precision 6466 Post Here
The ball bearing will be slightly snappier, but I would rather by a journal bearing and a good PTC 9.5 converter than a ball bearing and try to run it with a crap converter. It is up to budget. Any of these turbos will benefit greatly from a good converter. Not just spool up, but coupling. All of the 6766s I have run have been journal bearing, and they spool very well.
Would it be a good fit with a 18 blade 9.5? Assuming the 85 housing is what you prefer?
9.9 or so as a goal, I use the .63 housing. Usually a 17 blade works best for the rpm range of the combos.
