NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
The problem with the pa enable is when the pa line is dropped it. It goes into closed loop instantly and this can cause a big issues. cause the a/f ratio is not correct and it takes a split second for the exhaust to clear out to get a true a/f and not have any large corrections based the incorrect a/f .....
I use the same tune on the street as when I race ...I do a zero corrections in the area where I'm on the 2step.
This is done in the +/- correction tables and I just zero out the area where the two step rpm and boost is at....I leave all the other closed loop stuff alone ..
My alky starts spraying in the 9-10 psi and I leave at 3k rpm and that's about 6-7 psi boost ..
If you have any questions in box me a way to contact you ..I can explain better than typing it all out ..
So, what your saying is simply don't allow correction at your launch RPM?
Tune the launch area of the VE map as normal, with it being dead-on for your desired AF. Then as soon as it leaves those few "0 correction" cells (when you release the two-step/trans brake) correction will begin again if needed. Just allow one cell more for the exhaust to clear the un-burned fuel.
Am I understanding this correctly? I installed the 2-step in the fall and haven't tuned for it yet. This info is appreciated.
