Fastest Pump Gas / Alky Cars (updated 10.07.18)
Sydwyndr
Admin
Staff member
May 25, 2001
3,192
456
83
Burlington N.C.
www.piedmontdragway.com
List includes:
Name..............1/4 ET@MPH / 1/8 ET@MPH (Heads / Cubic Inches / Weight / Turbo / Engine Mgmt. / Trans)
(8 SECOND CLUB)
Who will be the first??
Aftermarket Blocks
(9 SECOND CLUB)
Robert Wilson...........9.03@148.8 / 5.78@121.9 (TA / 274 / 3630# / BW S476 / XFI / TH400)
Melissa Merritt .........9.36@143.05 / 5.86@116(TA SE / 016 Stage 2 / 3710# / 6870 3-bolt, XFI / 2004r)
Production Blocks
(9 SECOND DIAMOND CLUB)
murphster..................9.21@144.9 / 5.84@117 (GN1 / 234 / 71hpq / XFI / TH400)
Melissa Merritt .........9.42@144.61 / 5.86@116(TA SI / stroker / 3720# / 6870, XFI / 2004r)
pacecarta (87GN)......9.45@141.6 / 6.01@114 (GN1 / 235 / 3280# / 71hpq / XFI / TH400)
snyderjw1..................9.62@143 / 6.19@114
Brian Cotton..............9.67@138 / 6.17@113 (9/19/14)
pacecarta (86GN)......9.72@138 / 6.13@112 (Iron / 234 / 71hpq / XFI / TH400)
Phoneuy....................9.80@137 / 6.28@110 (GN1 / 249 / 3760# / 6766 / XFI / 2004r)
jdsgnx........................9.81@138 / 6.07@114 (Iron / 231 / 3610# / 71hpq / XFI / TH400)
JC'sGN.......................9.82@137 (6776)
Ron Bailey.................9.88@135 / 6.18@114 (GN1 / 249 / 6870 / XFI - TH400)
Just4play ..................9.898 @ 136.33 / 6.30@110 (Iron/234/ 3490# / CPT-6968/ XFI/ th400)
KidGlok......................9.90@136 / 6.36@110 (Iron / 235 / 3500# / 6765 / XFI / TH400)
1985GN......................9.91@137
(10 SECOND GOLD CLUB)
goche4......................10.01@138 / 6.41@109
RICHIE HIGH PSI......10.05@133
GNDriven..................10.06@139
Sydwyndr..................10.07@134 / 6.29@109 (GN1 / 248 / 3665# / 70gtq / XFI / 200-4R NLU)
TURBO 6...................10.12@132
HotRodGN................10.16@133 (Iron / 70gtq / XFI / 200-4R) 11/30/13
J-B Racing................10.22@136
cutt............................10.30@128
HiTech6.....................10.365@129
List has been updated for the top 10 in the 10 second category so to get on there you must knock someone off the list. There are MANY 10 second cars so this will give everyone something to shoot for. Are you quick enough to make it to at least the 10 spot?? :)
Grumpy
Thread killer
May 24, 2001
10,860
544
113
Andover, Ma
Iron, 231, 67**, Turbo Tweak Chip /Stock ECM, 3660#s, 200R4 LU converter ....2007 :eek: I forget the turbo .. I have to ask Russ.. Old age moment :p
come on !!! Me a NLU converter :p .... 9/11 LU
SloGN
I'm a ASSHOLE.....
Dec 25, 2003
3,542
241
63
40
Randleman NC
109 Block:
Name....................................ET (HEADS / CID / TURBO / ECU / TRANS)
(9 SECOND CLUB)
pacecarta....... 9.815@138 (Iron / 234 / 71gtq / Classic)
1985GN............9.91@137
Grumpy............9.94@138 (Iron / 231 / 3660lbs / 67**/ Stock TT / 2004-R LU)
jdsgnx..............9.98@134 (Iron / 231 / 3610lbs / 71hpq / XFI / TH400)
(10 SECOND CLUB)
Sydwyndr..................10.07@134 (GN1 / 248 / 3665lbs / 70gtq / XFI / 200-4R NLU)
SloGN........................10.15@130 (TA / 249 / 3700lbs / 67hpq / XFI / 200-4R 9/11LU)
murphster.................10.19@129 (GN1 / 234 / T netics 71 / stock TT)
Quik Six....................10.373@132 (Iron / 249 /3720 lbs. /6265JB / TT SD)
insane6.....................10.377@128 (Iron / 234/ 3620lbs / TE-67 / Stock TT / 200-4R LU)
TurboTnZ06..............10.69@131 (GN1 / 250+ / 3650lbs / TE45A / TT6.0 / 200-4R LU)
Stage Block
I edited my entry to show I have a 9/11 Lu convertor
SloGN
I'm a ASSHOLE.....
Dec 25, 2003
3,542
241
63
40
Randleman NC
Name...........................ET (HEADS / CID / WEIGHT / TURBO / ECU / TRANS)
(9 SECOND CLUB)
Stage Block:
109 Block:
pacecarta...................9.815@138 (Iron / 234 / 71gtq / Classic FAST)
Grumpy......................9.94@138 (Iron / 231 / 3660lbs / 67**/ Stock TT / 2004-R LU)
SloGN........................9.96@133 (TA / 249 / 3700lbs / 67hpq / XFI / 200-4R 9X11 LU)
jdsgnx........................9.98@134 (Iron / 231 / 3610lbs / 71hpq / XFI / TH400)
(10 SECOND CLUB)
blackgn1...................10.70@129 (Iron / 231 / 3580lbs / 6776 / XFI / TH350)
i updated the list for my time run I finally made it in the nines!!!!
  • Like
Reactions: garyk1970
SloGN
I'm a ASSHOLE.....
Dec 25, 2003
3,542
241
63
40
Randleman NC
Congrats!! 1 of only 8 109 / Alky cars in the 9's....
Oh and just like the minions from Dispicable Me say..... WHAAAAAAAAT!!!! Your faster than JD
hahahaha............JD must be on suicide watch cause i have not heard anything from him....................he know it's over............
Clint no need to sand bag there brother go ahead and post up your results :)
scojack_2001
Livin' Like A Refugee
May 24, 2001
1,174
20
38
36
Bear, DE USA
I'll add my name to the list
1.54 60'
10.97
123mph
Full weight GN, everything 3700+ pounds
TE-62
Dutt neck
Home ported irons w/stock valves
FTSS/Comp 210/215
9.5" 3400
200-4R
Video from yesterday @ Cecil County. Best pass is last.
Top Bottom
