Fastest Pump Gas / Alky Cars (updated 10.07.18)
Sydwyndr
Admin
Staff member
List includes:
Name..............1/4 ET@MPH / 1/8 ET@MPH (Heads / Cubic Inches / Weight / Turbo / Engine Mgmt. / Trans)
(8 SECOND CLUB)
Who will be the first??
Aftermarket Blocks
(9 SECOND CLUB)
Robert Wilson...........9.03@148.8 / 5.78@121.9 (TA / 274 / 3630# / BW S476 / XFI / TH400)
Melissa Merritt .........9.36@143.05 / 5.86@116(TA SE / 016 Stage 2 / 3710# / 6870 3-bolt, XFI / 2004r)
Production Blocks
(9 SECOND DIAMOND CLUB)
murphster..................9.21@144.9 / 5.84@117 (GN1 / 234 / 71hpq / XFI / TH400)
Melissa Merritt .........9.42@144.61 / 5.86@116(TA SI / stroker / 3720# / 6870, XFI / 2004r)
pacecarta (87GN)......9.45@141.6 / 6.01@114 (GN1 / 235 / 3280# / 71hpq / XFI / TH400)
snyderjw1..................9.62@143 / 6.19@114
Brian Cotton..............9.67@138 / 6.17@113 (9/19/14)
pacecarta (86GN)......9.72@138 / 6.13@112 (Iron / 234 / 71hpq / XFI / TH400)
Phoneuy....................9.80@137 / 6.28@110 (GN1 / 249 / 3760# / 6766 / XFI / 2004r)
jdsgnx........................9.81@138 / 6.07@114 (Iron / 231 / 3610# / 71hpq / XFI / TH400)
JC'sGN.......................9.82@137 (6776)
Ron Bailey.................9.88@135 / 6.18@114 (GN1 / 249 / 6870 / XFI - TH400)
Just4play ..................9.898 @ 136.33 / 6.30@110 (Iron/234/ 3490# / CPT-6968/ XFI/ th400)
KidGlok......................9.90@136 / 6.36@110 (Iron / 235 / 3500# / 6765 / XFI / TH400)
1985GN......................9.91@137
(10 SECOND GOLD CLUB)
goche4......................10.01@138 / 6.41@109
RICHIE HIGH PSI......10.05@133
GNDriven..................10.06@139
Sydwyndr..................10.07@134 / 6.29@109 (GN1 / 248 / 3665# / 70gtq / XFI / 200-4R NLU)
TURBO 6...................10.12@132
HotRodGN................10.16@133 (Iron / 70gtq / XFI / 200-4R) 11/30/13
J-B Racing................10.22@136
cutt............................10.30@128
HiTech6.....................10.365@129
List has been updated for the top 10 in the 10 second category so to get on there you must knock someone off the list. There are MANY 10 second cars so this will give everyone something to shoot for. Are you quick enough to make it to at least the 10 spot?? :)
Iron, 231, 67**, Turbo Tweak Chip /Stock ECM, 3660#s, 200R4 LU converter ....2007 :eek: I forget the turbo .. I have to ask Russ.. Old age moment :p
come on !!! Me a NLU converter :p .... 9/11 LU
Iron, 234, TE-67/.63 exh, TT CHIP/stock ECM, , 200r4 LU Converter, 3620, stock location I/C
Does it could if my 9.90 pass was on 5 cylinders? :)
10.7 at 129mph
10.8 at 130mph
Turbo 6776
Trans 350
FAST XFI
Iron Head
Cam 206/206 Roller
Weight 3580
10.7 at 129mph
10.8 at 130mph
Turbo 6776
Trans 350
FAST XFI
Iron Head
Cam 206/206 Roller
Weight 3580
Welcome to the new slo club..............lol.
109 Block:
Name....................................ET (HEADS / CID / TURBO / ECU / TRANS)
(9 SECOND CLUB)
pacecarta....... 9.815@138 (Iron / 234 / 71gtq / Classic)
1985GN............9.91@137
Grumpy............9.94@138 (Iron / 231 / 3660lbs / 67**/ Stock TT / 2004-R LU)
jdsgnx..............9.98@134 (Iron / 231 / 3610lbs / 71hpq / XFI / TH400)
(10 SECOND CLUB)
Sydwyndr..................10.07@134 (GN1 / 248 / 3665lbs / 70gtq / XFI / 200-4R NLU)
SloGN........................10.15@130 (TA / 249 / 3700lbs / 67hpq / XFI / 200-4R 9/11LU)
murphster.................10.19@129 (GN1 / 234 / T netics 71 / stock TT)
Quik Six....................10.373@132 (Iron / 249 /3720 lbs. /6265JB / TT SD)
insane6.....................10.377@128 (Iron / 234/ 3620lbs / TE-67 / Stock TT / 200-4R LU)
TurboTnZ06..............10.69@131 (GN1 / 250+ / 3650lbs / TE45A / TT6.0 / 200-4R LU)
Stage Block
I edited my entry to show I have a 9/11 Lu convertor
Clint,
Here is my update:
9.150 @ 147.7
TA Heads
274
3630 lbs.
76GTS
XFI
400 trans
Name...........................ET (HEADS / CID / WEIGHT / TURBO / ECU / TRANS)
(9 SECOND CLUB)
Stage Block:
109 Block:
pacecarta...................9.815@138 (Iron / 234 / 71gtq / Classic FAST)
Grumpy......................9.94@138 (Iron / 231 / 3660lbs / 67**/ Stock TT / 2004-R LU)
SloGN........................9.96@133 (TA / 249 / 3700lbs / 67hpq / XFI / 200-4R 9X11 LU)
jdsgnx........................9.98@134 (Iron / 231 / 3610lbs / 71hpq / XFI / TH400)
(10 SECOND CLUB)
blackgn1...................10.70@129 (Iron / 231 / 3580lbs / 6776 / XFI / TH350)
i updated the list for my time run I finally made it in the nines!!!!
Congrats!! 1 of only 8 109 / Alky cars in the 9's....
Oh and just like the minions from Dispicable Me say..... WHAAAAAAAAT!!!! Your faster than JD
hahahaha............JD must be on suicide watch cause i have not heard anything from him....................he know it's over............
Clint no need to sand bag there brother go ahead and post up your results :)
I'll add my name to the list
1.54 60'
10.97
123mph
Full weight GN, everything 3700+ pounds
TE-62
Dutt neck
Home ported irons w/stock valves
FTSS/Comp 210/215
9.5" 3400
200-4R
Video from yesterday @ Cecil County. Best pass is last.
