Feeler: What will this kinda car bring?
84GNwith87eng
84 Regal Grand National, rough body but has NEW floorpans from postons
-swapped interior to 87
-87 engine/trans with only 500miles on rebuilt trans
-new fuel lines/walbro 340/alternator/front-end rebuild/shocks all around
-87 rims
-30# injectors, rjc powerplate, 3" MAF pipe/K&N filter
few things wrong: no a/c system, heat only blows from defroster, power windows/locks seldom function
what can I expect to get for this car? It runs real well, has new carpet and headliner, probably needs new doors and a lot of bodywork
any ideas?
If its the car I think it is, $3k to 4k. Was it sitting in front of Josh's shop most of the summer?
No, it wasn' there during the summer, it has been at Jim's before though. I didn't meet Josh until Fall. It has been at his shop recently though for the fuel-line work.
What's your opinion on the car?
Had an unpainted rocker that was barely welded on? Major wiring issues? Im pretty sure its the same car. Jim told you stop dumping money into it, its a lost cause but you had him put injectors and some other stuff in it. Same car?
Yes, it had an unpainted rocker, but no it wasn't barely welded on, it was welded just fine. He didn't put injectors on it. Just some spark plugs/wires and spring cleaning stuff.
Well in case, that particular car is worth more in parts than it is whole.
I agree to as a parts car .. very easy to keep dumping $$$ into a dead horse :eek:
