T-CHRGD
- Oct 28, 2006
kirban 2 cents worth
this issue we addressed years ago when we made the first fiberglass hoods. the easy method is don;t mount the spring on the hood instead mount it on the core support look at the small half moon area and I believe I recommended cutting down the original spring and simply slip it under the half moon lip on the core support. presto nothing else needed.
My description may not be accurate but you will clearly see somewhere on your core support not the hood this half moon area simply pry it slightly and loop the spring into it.
denniskirban@yahoo.com
I will have to look at mine, but I think this is what I did (it was Long ago). I know I cut the stock spring.
That Jeep spring looks like a great idea !
