Oct 17, 2009 #1 A aliaZ New Member Joined Oct 17, 2009 Messages 1 Hi! Are most billet cranks made with a 5/64" radius? Weber Racing sells some cranks with a 5/64" radius, I thought 1/8" was typical. Has anyone run this crank? Did it require machining the rod bearings for clearance? Thanks
Oct 17, 2009 #2 D DailyDrifter The Slow and the Curious Joined Dec 5, 2007 Messages 5,118 If bison finds this thread he shoud be able to tell you.
Oct 18, 2009 #3 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 You need to check everything. It may not need anything. You may need to use the narrow bearings but everything has to be checked. Chamfer as necessary. Most machine shops will make a jig to hold the bearings in and they turn them in a lathe.
Oct 18, 2009 #4 G gnxtc2 Well-Known Member Staff member Joined May 28, 2001 Messages 4,203 bison said: Most machine shops will make a jig to hold the bearings in and they turn them in a lathe. Click to expand... Yep. Billy T. gnxtc@aol.com
