- May 28, 2001
Here is the first log on the new system. Plse look at it, and see what you think.
I have some obvious issues like a boost read, fuel psi, etc, All of which should read 0, as the engine has not been fired since installing.
1.I'm not sure how to correct the inaccurate values. I'm "assuming" they are corrected, using the published ranges of the sensors. Y/N?
2. What is the "reflash logger" for? When should this be done?
TIA,
TIA,
