Flair help please...?
chrisaxl87
Was wondering best way to tackle the flair gasket issue?my rear side flair glue is let go and I was wondering best way to glue it to reattach I noticed the front lower to rear is do as well? ... Thanks
Perhaps you can reply with a pic? To the best of my knowledge the flairs have a rubbery welting between them and the body panel however I do not remember any sort of adhesive being used. It is more of a sandwich type of fit.
There is No glue or adhesive used in attachment of the flares. It is just screwed on tight and a rubber welting is in between so the flares do not scratch the body. Even when new the bottoms were not a perfect tight fit.
Oh ok thanks the owner before must of tried something like that...
Something was in there
I would suggest removing the flair and doing some cleaning. It looks like there is a large buildup of white wax residue in there cleaning it make it look alot better.
One thing I have noticed with some flairs is overtime they tend to confirm to the screws that hold them in. The result is the flair leaving a little gap like you have pictured. You may want to use a larger washer near the screw to get the flair to hug the body closer/pinch the welting more.
