Flat tappet cam pressure lube..
Chuck Leeper
Toxic old bastard
Staff member
NE1 use the Comp lifter bore grooving tool?
I used it on the ft in the Hemi, and on the last 109 I built. No cam failures on either engine.
The tool puts a groove in the lifter bore, to direct oil onto the cam, b4 it comes in contact w/ the lifter.
Going to do this engine, too. We'll see.:cautious:
Chuck
I thought that was more for the Chev lifter bore! I also see they offered a lifter with a lube hole in the end of it? Interested in more info also
Chuck
They're both the .842 bore. I've not seen the lifters w/ the EDM hole in them, for sale, for quite some time.
Would this affect overall oil pressure or how the lifters spin in the bore?
I use to file a small groove in the bores, but now I only use roller lifters. I will not use flat tappet anymore.
