What happened? I was driving normally down the highway and after getting off an exit I noticed smoke coming from the back of the car. I stopped to look and found trans fluid just pouring out the front of trans and also from the flywheel cover hole.
Right before I noticed the smoke the car was not shifting right thru the gears.
I went to refill the trans to drive it home and it just poured out the minute I put it in.
What could have happened? Did I blow a seal? What could have caused this? The trans was working good before hand. It is stock except for 10 vane pump and shift kit.
paul
paul
