The motor is new in the car, turbo, etc etc..is all pretty much new. I been working on getting all the drivability stuff aired out on it. So experience with this car to me prior than Oct 2003 is ??? The wastegate rod was put on the car by hand initially, whereas it had zero tension. An ATR bleeder was being used to regulate boost.
For the last couple weeks a high blm condition was being chased down on the car. While the BLM's were pegged, I never got on the car. Along with a lot of other stuff that was wrong, now the drivability is great. So on went the alky kit..dialing the kit in, is when I noticed this condition of the 8-10 PSI surging. I thought..too much alky .. So after powering down the system come to realize it does it also without the alcohol..so its not a fuel issue.
Thats where it was left..so I was thinking wastegate issue. Another wastegaste was installed, a HD one, and this time tension was put on it.. since no tension had cuased this..lets try some tension. Same deal.
Bob.. will try the different MAF, probably be a couple days tho till I can get to play with it again.
alb84, I have read about the external spring. can you elaborate a little further. What kind of spring, where to mount, what tension, etc.. I've only used stock and HD style WG diaphrams. So I assumme the spring goes from puck arm to WG diaphram?
thanks guys..
Almost there..car is at 90 percent
BTW Bob..aside from the MAF dropouts..pretty awesome stuff 25 PSI on 93 with zero retard.. I love the way the translator/exctender controls the O2's whereas you dont have that huge spike in O2's and keeps them flat..really nice curves. good Work
... appears to be an excellent match with my alky kit.
