434nova
- Sep 30, 2013
I finally took the flywheel out of my car that was broken. When I went to put the a used stock flywheel in i noticed it had what look to be 3 dime size weights and there weren't as many holes drilled in it. Motor was rebuilt in the past I'm not sure if it's internally balanced now. Cause stock is external right ? Does this look to be a stock flywheel for a 87 lc2 engine. Don't want to put the flywheel back in and find out that it's vibrating, etc. Here are the pics.
The one on the right is the one i just took out the car and the one on the left is what I am replacing it with. The one on the left even has a extra hole at 6 o'clock. Thanks in advance.
